I should of searched more.
Been trying to get a second fuel pump on this new motor and space between the front cover/balancer and fan is a major issue. Decided to cheap out and buy a wrecking yard electric fan off a 1993-1996 Lincoln MkVlll. After placing the order I did a search here and found they are a bit too thick. I was hoping to find something that would clear a front cover mounted fuel pump that drives off the power steering gear. Looks like the search goes on. It's a crying shame they don't still have the port in the block for the mechanical pump to attach to. I don't mind having one electric fuel pump for priming after injector changes and to supply more fuel when required, but 2 just seems like a headach since i have not had good luck with them lasting.
Would this work? Not sure how much room you have/need.
http://www.dieseltrans.com/dodge/ASSASSIN.htm
Friend of mine has one and is putting it on his 3rd gen soon.
berok
04-27-2006 10:01 PM
jiMMyCTD
07-12-2004 03:52 PM
Maccandy
05-16-2004 09:25 AM
JaimeZX
05-12-2004 11:36 PM
