I need a Turbo upgrade.
Im looking to do an upgrade to my truck. Ive been seeing alot of people swapping there turbos to a HX35. Where can i buy one? and how hard are they to install? only mods i have done now is a straight piped exhaust, and the pump turned up. Thanks guys
then only real upside of the hx35 is the 12cm wastegated housing and the map width enhancement slot
the 12cm is good for the 5speed but the compressor side isn't much better than stock on an intercooled truck
If your gonna fork out the cash for a new turbo make it worth while. As stated above the HX-35 is barely an upgrade. A HX-40 would be a decent priced upgrade but not great for all out hot rodding as they dont like high boost. If you want to spend a little more for a real good turbo get a 62/71/14 S300 turbo. They are available from many companies such as HTT and Industrial Injection. Either turbo would be a big upgrade over stock. Pick a HP figure you want to shoot for and buy the turbo that will support that. The HX-40 will be good to about 325-375hp and the S300 around 400-450hp.
Well what site could i got to? and are they as easy as just unbolting the old turbo and bolting up the new one? Also i would like to buy a turbo thats ready to bolt on straight from the package. Thanks
If you decide to go with the compressor upgrade then I think most people have been going with Gillett Diesel Service (GDS) stage II rather than the HTT due to price and availability.
Here is the Gillet site unfortunately there are no prices but the stage II is in the range of $200 from what I've read on here.
http://www.gdsdieselparts.com/1991_5...o_upgrades.htm
The compressor upgrade requires some work though.
He's got a 5-speed. You can upgrade the compressor to 60 mm which is $155 till the price increase in 2009. A exhaust hausing will make it spool up faster and you NEED a 366 govener spring.
I've got all 3 of those parts in a box awaiting installation- This week yea!
M
M
stage 2 ill second it in a recent diesel power they did the swap on a non intercooled truck. i got mine and got the 3 inch v band clamp and got a rubber plumbing collar from a hardware store. i slipped it over the turbo and the housing and used like 4 clamps the thing has seen lots of boost and still hasn't come off.
NJTman
07-05-2012 12:55 AM
LilBigd02
02-28-2007 09:31 PM
12valve
14
02-22-2007 10:07 PM
