I need the torque specs for the crank pulley and timing cover
I'm replacing my front crank seal on my truck and I need the torque specs for the crank pulley and the timing cover.
Thanks
Lucas
Thanks
Lucas
A good service manual is priceless. One piece pulley/vibration damper 92ft-lbs. Two piece pully/vibration damper 148ft-lbs, then 57ft-lb. 10mm timing cover bolts 18ft-lb. All 10mm bolts on engine torque to 18ft-lb btw.
Thanks guys. I'm having trouble getting the crank pulley off. I thought I read on here that you just take out the 4 bolts and it should come off? Or am I imagining things and I need a puller?
bobsallyh
11-06-2014 07:33 PM
dochawken
10-23-2012 06:56 PM
Diesel-Dan
05-26-2004 04:42 PM
