I Killed My Truck -help !!!!!!!!!!!
REALLY old dog
Ok i was rewiring od with a switch , had that done (Had`nt tested yet but done) I wanted a light to remind me it was in overdrive. used a test light and picked up 12 v from back of fuse box ,On far right dark blue wire going to stake on,some one had a clio on on it ahs it had been used before
there was no problem using test light ,light on switch worked and everything, when i went to put the wire on the switch (didn`t eaven get it on ) it killed the motoe melted rubber coating on wire .
Now truck wont start all gages work except battery, fan works ,head lights work, starter doesn`t eaven try.
iVE CHECKED ALL FUSES, MY THOUGHT IS HEAD LIGHT SWITCH CARRIES EVERYTHING TO IGNITION AND EVERYTHING ELSE , IT HAS A BUILT IN BREAKER.
MY GUESS IS THAT IS WHAT WENT.
Any ideas would be apreciated!!!!!!!!!
OH yea i checked the plug to the cumputer and no bern marks or sighns of heat.
THANKS
(DUMMY) Claude
THANKS
(DUMMY) Claude
There are fusible links that are inside the wiring harness under the left hood hinge. I would guess you burned one of these up. Just get an inline fuses and replace as much of that part of the harness as you can.
trex
05-10-2011 10:18 PM
Grayeeagle
10-12-2009 02:09 PM
RyeThomas
07-11-2007 04:31 PM
CUMMINSBILL
06-06-2003 10:02 AM
