I have a loud sound coming from the shifter??
Old 12-09-2005 | 11:14 AM
tboling's Avatar
I have a loud noise coming from my gear stick. It only dose it in 1st and 2nd and at low rpms in the rest of the gears and when u let off the gas. It sounds like a bearings out and is grinding gears up.It won't make this sound when u keep the trans under press with the rpms up but coming down it sound like its going to come apart. when its Idling its sounds like a bad throw out bearing and when u press in the clucth the sound go's away. Have any of u had this before? O yea Its a g360 Get's U A Rag ready
Old 12-09-2005 | 12:12 PM
loch's Avatar
My ssters does that as well, even after it was rebuilt, but id take it to shop you trust, it might leave you stranded.
Old 12-09-2005 | 12:48 PM
Alec's Avatar
Sounds like a bearing died, and is bad under thrust load from deceleration. Better take her out and apart before it takes itself apart. : (
Sorry to hear that you are in that situation.
Old 12-09-2005 | 01:18 PM
Redleg's Avatar
Just sounds like the inherent rattle they tend to get. You can fuss with the linkage, I've read some installed various pieces of rubber on the linkage to cure it. It quit on me for a while after reinstalling the t-case, but came back. I just hang a work glove on it for the time being and it stops it.
Old 12-09-2005 | 05:32 PM
Gunrunner's Avatar
if it's something new. it's probably the input shaft bearing---very prone to failure
Old 12-09-2005 | 05:55 PM
This sounds a bit worse than the normal gear rattle. I'm thinking input shaft bearing.
(not much of a guess, that's what usually gets munched)
Old 12-09-2005 | 06:42 PM
BearKiller's Avatar
I ain't no expert, but it sounds like the throw-out bearing to me.
Old 12-11-2005 | 02:32 PM
tboling's Avatar
Well guys I wish it was wear just a input shaft bearing but it's much deeper than that. It's on the cluster shaft in the bottom of the case. I have removed the shifter top and bearing carrier for the input shaft but every thing on the top side looks as good as new. After I remove all the top main shaft gears and syros I will fined my problem. It's not looking good I would say every thing on the cluster shaft is gone. I also belive this is were that bad shaking is coming from. I smell an Nv 45oo coming on
Mlucas
11-29-2009 10:44 AM
njmaier
09-11-2006 07:27 PM
alexandr
07-26-2005 09:37 AM
B-Peterson
20
12-04-2002 07:03 AM
Quick Reply: I have a loud sound coming from the shifter??
