I have a 93 cummins, and want to use my 24V (98.5) fleetguard filters...is there any
Can I use the same fleetguard filters in my 93 as I use in my 98 1/2 24V?
I don't believe they are the same, if I recall correctly my Cummins dealer has a little chart with the part #s and the corresponding year of truck and the 24V's and the 1st gen filters are different.
That brought up a bigger question.
I didn't realize that the 1st gen's and the 94 to 98 12Valves were considered "different". SO, am I looking for a totally different filter for my 12V because it's pre 1994, or are they all the same until you get to 24 valve
I do believe that the 1st gen filters and 2nd gen 12V filters are different. I do know that even the 93' filters are different versus the 91 or 92 since on the little reference sheet the 93' has its own numbers for the filters.
i would check to see if the 24valve filters wont work on your 1st gen cause i know the 24valve fleetgaurd's are considered and upgrade for the 2nd gen 12v's and you cna use them...I know i do
All Fleetguard Filters for our trucks are all the same thread and base pattern. The only difference is the 3rd Gen filters have a fluted bottom and can be removed from the bottom of the truck. I use Fleetguards Stratapore filter P/N LF16035 but I still have some of the old P/N LF3894 which is also a Stratapore. As I said the only difference is in the fluted bottom.
Bob
I just did a quick check on the 6.7 and it also uses the same filters.
Bob
Puke
07-23-2007 12:33 PM
rodboy
14
01-13-2007 10:45 AM
Boondock
01-12-2007 08:13 PM
S.Dodge
11-12-2006 08:02 PM
tishmael
11-07-2002 11:38 AM
