I found my pressure problem
Old 11-09-2005 | 11:35 AM
tboling's Avatar
I had talk with Jp at SCHEID DIESEL in Terre Haute IN my 5.9 is boren 20 over an it makes more crank case pressure than it's supost to.When the crank seal would hold it would blow vale cover gaskets left and right. The stock vent is not enough vent thats why some of the pullers I know vent the vale covers. So I bought a frount timing cover vent from a 24 vale an dilled a hole in the frount vale cover an put on a oil filler cap. + high rpms also added to my pressure problem every thing is a ok now. An by the way my P7100 is almost finshed It won't be long now v8 diesels beware
91 DODGE RAM 3500 GETRAG 5SPEED 354 GEARS REG CAB 2WD LE PW LOCKS WINDOWS\MIORS BANKS 3 HOLE POD TACK BOOST PYROMETER 4INCH EXSHAUST COLD AIR KIT BIG INJECTORS LOTS OF FUEL VE PUMP WITH LOTS OF GOODIES AND HOLLEY LIFT PUMP AND NOW WATER AND METH HX35 TURBO For my next hat trick a p pump that tacks way over 4000 rpms I HOPE.
Old 11-09-2005 | 11:43 AM
G1625S's Avatar
Glad you got it solved! I hear those folks at Scheid know a thing or two about the 5.9
Old 11-09-2005 | 11:55 AM
tboling's Avatar
In my book SCHEID the's best I have done lots buying parts from Enter Prise Engine also Doug at EEP is a good man to talk to when having trouble. I'm a true SHCEID man my self.
T BOLING SMOKEN IN THE BLUE GRASS
blackram2500
04-29-2010 04:36 PM
LanceD
02-22-2006 08:21 PM
RBRam
04-12-2005 04:26 PM
INsIdious
03-24-2004 08:42 PM
tishmael
02-05-2003 11:36 PM
Quick Reply: I found my pressure problem
