I/C thermostat housing interchange
Old 10-18-2009 | 10:41 AM
BHD's Avatar
BHD
I want to swap in the crossflow I/C style radiator and was wondering if any of the 2nd gen t-stat housing/waternecks would work. I just had my radiator cleaned out and it's not long with this world, so I was thinkin of upgrading to the later style that is more efficient. I know I can get a new one from Cummins but I like used prices better.
Old 10-18-2009 | 12:48 PM
NO_SPRK's Avatar
Sorry I don't know if it would work but I'd like to knoe if you had to change out the radiator support to fit the cross flow radiator
Old 10-18-2009 | 01:12 PM
CaptainChrysler's Avatar
Yes the 2nd gen housing will fit. It is set up for a check valve that vents to the "bleeder" port in the cylinder heads.Basically it is a check valve that burps air. It is my opinion that this is the reason a 2nd gen seems to have a more stable temp sweep while warming up. The 1st gen's I have been around seem to climb a little higher than normal, then the thermostat opens and it stabilizes.
To swap the 2nd gen parts you will need the housing w/ fitting, check valve that goes into the 1/2" NPT port in the head, and the hose to connect the two.
If you don't want to, just plug the hole in the thermo housing.
Swapping the rad will require a newer style rad. support or some fabricating.
Old 10-18-2009 | 01:53 PM
BHD's Avatar
BHD
I planned on fabbing the radiator support to make the I/C rad fit, would I need to fab the 2nd gen t-stat housing for the alternator bracket???
Old 10-18-2009 | 02:52 PM
Crazy Matt's Avatar
Just get a 2nd gen or a later ic t stat housing. The 2nd gen takes a bigger t stat tho
Drilling a small hole in the stat also helps stabilize water temps.
Old 10-18-2009 | 07:19 PM
The 2nd gens seem to take a lot longer to warm up, though. I don't like that.
Bookshelf
05-30-2009 01:17 AM
Dan Marino
05-16-2008 05:10 PM
Ace
08-01-2007 09:31 PM
TxDiesel007
02-18-2007 01:29 PM
Redleg
03-03-2003 04:29 PM
Quick Reply: I/C thermostat housing interchange
