hydroboost swap question
Old 03-14-2015 | 06:36 PM
Vader93's Avatar
Hey yall. I know im probably kicking a dead cat here but i got a hydroboost unit off of a 98 cummins and i want to put it on my 93. I have researched it but see mostly threads about later units and chevy units. Will this unit work. If so what else would i have to do other than drill 2 new holes, shorten push rod. Thank you in advance
Old 03-14-2015 | 06:41 PM
Vader93's Avatar
Just an fyi i will be using my stock power steering pump. Will the brake lines hook straight ip to the master cylinder or will they need adapting. I got the unit with all the lines still attached but dont know which lines go where on my pump. Thanks
Old 03-15-2015 | 10:10 AM
mknittle's Avatar
The pressure line runs in a loop from the pump to the booster to the power steering box .There will be two return lines. One from the booster and one from steering box. On my jeep I ran both returns to a "T" and into the return line to the pump.
Old 03-15-2015 | 03:29 PM
Vader93's Avatar
Thank you. I had read about just t-ing the return lines. Im just curious if the my stock brake lines will hook up to this master cylinder or if theyll need adapting. Thank you for your response
Old 03-15-2015 | 05:01 PM
mknittle's Avatar
I would like to know that also. I love thw one in my jeep and it would no doubt be an exelent swap in a first gen.
Vader93
03-28-2015 08:55 AM
LanceD
10-14-2009 04:37 AM
LanceD
07-07-2009 04:45 PM
Sea Bass
12-11-2006 08:59 PM
DL1221
08-09-2006 06:33 PM
