how to wire an external voltage regulator
Old 01-18-2016, 04:17 PM
j_martin's Avatar
Originally Posted by 918dodge
With my truck running I pull the plug and touch my test light to the green and blue connector and it shows that both have power on them
I would assume that would be correct. It indicates the field coil and brushes in the alternator are good.
If you ground the green one, the alternator will full field. Battery voltage will go up, and you'll hear the load increase on the engine. If you ground the blue one you'll burn something out. Actually, when you put the test light on the green one, the battery voltage should go up some.
Are you pulling the plug off the PCM, or is there an external voltage regulator on yours? What year is your truck?
j_martin is offline
Old 01-18-2016, 04:26 PM
918dodge's Avatar
My truck is a 06 dodge 2500 with the 5.9 I just went over everything and changed the voltage regulator had my alternator tested it passed put it all back together and seems to be working I just have to get my power wire to a key source because it's on the battery. ..
My 1st shot at doing this is had my ground wire for the regulator on my power wire I was doing it all in the dark with a flash light just got them mixed up and I think that was my problem it fried my reg . My battery charger I have says my battery is at 100% and my alternator is at 199% but I have low voltage
918dodge is offline
Old 01-18-2016, 05:11 PM
918dodge's Avatar
Now my main battery is dying and my 2nd battery is staying at 100% im last again
918dodge is offline
Old 01-18-2016, 06:34 PM
918dodge's Avatar
Now it's over charging what could cause that ?
918dodge is offline
Old 01-18-2016, 07:47 PM
peckens's Avatar
You will probably have much more help in the 3rd gen section. You are in the first gen 89-93 trucks.
peckens is offline
Old 01-18-2016, 07:48 PM
918dodge's Avatar
OK thanks I'm a newbie sorry
918dodge is offline
Old 01-18-2016, 07:50 PM
j_martin's Avatar
I have no idea what to tell you. You must be too poor to pay attention. This is the first gen forum (89-93) You have a third gen Dodge.
j_martin is offline
Old 01-19-2016, 09:08 AM
patdaly's Avatar
You have corrosion at the terminals or in the battery cable. One side is receiving the charge from the Alt, not the other.
Either that has to be it or you have a bad battery, but I assume you had it tested.
patdaly is offline
Old 01-19-2016, 02:10 PM
jrs_dodge_diesel's Avatar
Thread closed.
Duplicate thread in 3rd gen forum ----> https://www.dieseltruckresource.com/...-south-324076/
jrs_dodge_diesel is offline
TurboAZ
08-27-2013 09:26 PM
jcb
05-07-2006 08:03 AM
flycl65
01-26-2006 12:00 AM
westcoaster
06-23-2005 10:56 PM
banks twinram
05-01-2005 10:35 PM
Quick Reply: how to wire an external voltage regulator
