How reliable is your 12V 1sr Gen...really
#106
well, my Truck has never left me on the side of the road and I have never had to fix anything in a NAPA parking lot in the middle of a trip. That being said, once you look past the cummins power plant it is still a consumer truck and one that is 20 years old. so there are going to be issues like axle seals and bearings, warn trim, wiring gremlins, and so on. Does that make it unreliable? I don't think so. As long as my monthly repairs don't cost as much as a truck payment and don't leave me stranded, I am still ahead of the game with the insurance and licencing money I save
Sent from my Transformer Prime TF201 using Tapatalk
#107
Thanks, then I can say that you can completely rework the front end, including the king pins and u-joints, in a good weekend. All the info and parts sources are in the sticky. Even if the front end is not toast, it wouldn't hurt to go through it, IMHO...Mark
#108
Shops are TERRIBLE. I took my '72 crew to get an alignment (read: toe adjustment) and they upcharged me for having a "modified" truck because it was harder to adjust.
The truck had stock suspension but 37" tires... Makes no sense to me why a little dodge dakota 2wd with Camber caster and Toe ajustment and all the 2wd control arm madness is half as much to install. They just like to use the "old truck" leverage to win over the general public. No WONDER people who aren't mechanically knowledgeable/skilled get convinced that they need a new car every few years! The old "junk" they drive keeps getting bashed on by shade trees!
#109
I had a shop tell me that a few years ago on another truck. They wanted $2,200 to go through it. I didn't believe them as the truck tracked nicely with no play or other issues. So, I went to a Les Schwab and had them put the truck up on the rack and look it over real close with me. Front end wasn't shot. It was only getting close to needing new lower ball joints (2wd truck) and everything else was fine. You could see the play as you lifted up on the tires. I had them replace all 4 ball joints as I was getting ready to get new tires. The "totally smoked" front end cost me $540 and that was having them do all 4, parts and labor. So, you may find differently when you go through it yourself or have another shop look at it with you.
Bill
#110
Bill
#111
This one!
#114
#115
Bill, that truck doesn't have ball joints, it has king pins, and if they are loose, they really need attention. One of mine was cracked...Mark
#116
Bill
#117
Bill,
You have ROLLER bearings on the bottom of the knuckles that are serviceable with grease. The top kingpin bushings are nylon and EASILY replaced (4 bolts to remove knuckle cap).
You are being scammed to put cash in his pocket, my friend.
This Axle the D60F is the MOST sought after OEM unit EVER put into a vehicle by hard core rock crawlers for a reason! They don't just get "shot" with an easy 200K miles and 20 years on ROAD.
#118
Bill,
#119
Put inspection paint on the components in hidden areas. I bet none of it will be broken around the "ball joints" if you do end up getting this "service". Highway Robbery.
#120
I was wondering about that. I ordered a repair manual from Geno's but it hasn't arrived yet. The guy at the shop specifically said upper and lower ball joints, but I thought it had king pins. Whatever it has...they're worn out, along with a bunch of other stuff. Seems too soon (185K miles) for the front end to be completly shot. I've driven old trucks my whole life, most of whick were 4X4's, and most with many more miles than this 92 has on it, with no front end work save maybe tie rod ends. But, it is what it is.
Bill
Bill
Bill, it is not that hard to do, I did mine last June, see here . I agree that it must have been abused to have failed, but I really didn't have any obvious play, except the Death wobble...Mark
