How much tranny fluid do I need to do a filter change?
I think you'll only get 4 or 5 qts from the pan. The rest is in the system. If you want to get it all out I'm told you must remove the return line and run the truck while an assitant catches it. In that case, I'm not sure how much you need total.
From the sticky: 10.2qts in the 518, a little less in the 727:
https://www.dieseltruckresource.com/...1&d=1210280772
phatboy
11-23-2008 11:18 AM
RedRacer44
06-21-2007 12:05 PM
tufamc
05-04-2007 09:30 AM
snowmanx
10-23-2006 05:38 PM
RobG
08-18-2005 01:22 PM
