How much farther back is the long turbine housing than the short?
How much farther back is the long H1c/HX35 turbine housing than the short?
I read anywhere between 1/2" to 1 1/2" I need a more solid number to know if I have enough room.
P.S. H1c/Hx35
P.S. H1c/Hx35
When I put my 'HX-35 on my black crew and installed a Diamond Eye 4 inch down pipe at the same time. I had plenty of room on the firewall side.
I did grind and modify my stock down pipe hanger, that bolts to the adapter plate, for the larger down pipe at that time.
I converted my non-wastegated turbo to a wh1c and the standard exhaust pipe had to be moved back some. It is almost touching the rubber cover over the heater A/C but no issues yet. I just drove it from Kansas to CA without anything burning. I don't know what kind of rubber is in that cover but it seems like it can take the heat.
The only other issue I noticed was the pipe is almost touching a frame cross-member when it humps over the rear axle but I'll fix that when I replace the muffler soon because it has none now.
On mine I will have to modify my down pipe as I don't have the room to move the rest back It is really tight around the transfer case. We shal see how it goes. Hopefully I can put together a turbo with the short housing. If funds allow.
I may end up doing that but it took me two days to get that thing to fit in there so if I can avoid taking it out I will Funny how sometimes the simplest thing can be such a PITA.
Mark,
The long turbo housing is 4 1/2" from the face for the mounting plates to the flange face. Unfortunately, the only short housing I have right now is mounted, but I measured it at 3 1/4". So, the long housing is 1 1/4" longer.
When I had a stock downpipe, I removed the swaged section just before the flange, which I recall was just over an inch, and not quite the full difference.
Mark,
That's what I was looking for. I am exploring my options Money is tight right now so I put some misc. stuff i can't use on ebay to get Turbo money. I want to do the GDS 14cm short turbine housing but it isn't cheap. the long ones are cheaper. but more work and the consolation prize is a HX35. so no mater I win.
Tiara3100
28
05-30-2007 03:12 PM
600 Megawatts
01-30-2005 10:51 AM
dart440_72
07-10-2003 08:00 PM
