How good is the A727 auto trans.?
Old 09-21-2007, 06:50 AM
JD730's Avatar
Originally Posted by dumptruck200
Not trying to hi-jack the thread, just wondering if this is the same 727 International used in the 78-era Scout?
I've got my hands on one.
dumptruck200
I pretty sure it's not the same, the bell housing pattern might be similar. I think the diesel trans case is unique to the diesel's and the V10 (later years). Internals are similar, but probably aren't beefy enough for service behind the diesel.
For example:
I have taken apart a 727 from a 77, A518 out of my 93, 47RH from a 95 and a 47RE out of a 96.
The front planetaries in all of these transmissions will work in any of them, but they are different.
The 77 727 has an aluminum caged 3 pinion planetary.
The A518 has an aluminum caged 4 pinion planetary.
The 47RH has an aluminum caged 5 pinion planetary.
And the 47RE has a steel caged 5 pinion planetary.
Old 09-21-2007, 09:28 AM
rovingbenz's Avatar
I'm just saying it is a Chrysler 727. It will only fit IH. I changed out a couple of BW's in early IH pickups and they work great.
Ryan
Old 09-21-2007, 10:45 AM
JD730's Avatar
Oops, I think I misunderstood. At least the rest of the info will be informative.
Old 09-26-2007, 07:31 PM
dumptruck200's Avatar
Thanks guys. I checked it out on the web; Rovingbenz is right, IH used the Chrysler 727.
I was gonna replace my Getrag, but I like shiftin' too much!
Old 09-26-2007, 07:52 PM
gooseman495's Avatar
The 727 trans is a 47re without the overdrive unit behind it. Same clutches & steels. The planetaries not as beefy. You can put 47re planets in it. The only weakness to this trans is reverse band. If you get stuck & shift from drive to reverse to many times you will smoke the reverse band.
DodgeDiesel61
06-03-2008 07:50 PM
grandpa ralph
06-02-2008 04:47 PM
Captain Dean
04-30-2006 11:01 AM
Captain Dean
04-10-2006 04:33 PM
ckennedy
09-27-2004 11:58 AM
Quick Reply: How good is the A727 auto trans.?
