how do PODS compare to Bosch 190's
I ask because they seem to be that only ones thatare affordable.
also some companies are listing the injectors for 89-93 while others are stating only 91-93 probably meaning only intercooled models. ???
190's are cleaner(less smoke for the power)but don't make as much hp!
I notise that your truck is a 91! This is a split year! 89-91 have a larger hole in the head for the inj. 91.5-93 the hole was reduced to help prevent cracking there, and so, the inj tip had to be smaller! if you have a intercooler on you truck then your's is a 91.5!
POD's are cheap, dirty, and hot. Most bang for the buck for a play-only truck.
190's will do nothing for your non-intercooled truck, don't waste the money.
The non-intercooled trucks can use the 7mm injectors, there are adapter sleeves for that purpose.
