How can I get 400-500hp?
Old 02-25-2008, 07:55 PM
Dean Snow's Avatar
Originally Posted by C/PRD/
Dean, what charger are you running in that setup? I seen your sig says 417 on #2.
Borg-warner (schwitzer) s372
specs are as listed:
Specs:
Compressor Wheel Inducer - 71.8mm
Compressor Wheel Exducer - 101.9mm
Turbine Wheel - 83mm
Yes, it lags like hecks. But once she lights I"m gone. It's Supposed to be able to support like 700-1000hp
It can run up to 80lbs of boost without a problem but i can only run 45 as i run out of fuel! It will hit 52 with some water meth.
Here is an ebay aution for one if anyone is looking for one. I'm not affiliated with the auction. http://cgi.ebay.com/ebaymotors/Borg-...spagenameZWD1V
Old 02-25-2008, 08:23 PM
bgilbert's Avatar
Dean, you'd make more power with a smaller s300 properly sized for a low rpm VE motor, like a 64/71. What you have would be better suited for a p-pumped pulling truck. Like I try to tell my ole lady, bigger ain't always better.
Old 02-25-2008, 08:50 PM
RonA's Avatar
Transplant a p-pump converted motor into it. A bit of pump work, head work, a set of twins and you'll have your power and then some.
Old 02-25-2008, 08:54 PM
Dean Snow's Avatar
hahaha, only reason i went that big is because my truck is a project truck. i plan on soon in the future trying to get it to nearly 650 horsepower. but its rated to work from 200hp-1000hp. so it works well. only about 2-3 seconds of lag.
Old 02-26-2008, 07:34 AM
C/PRD/'s Avatar
Is that what the nitrous is for? That is freakin huge man.
Old 02-26-2008, 02:27 PM
JAyers's Avatar
My truck on #2 only hits about 1450* and by then im at 110+mph. With the nitrous it may cool it off alittle but its hard to see on the guage. Ive been driving it every day for the last two years like this. Heck i even keep the bottle behind the seat, it always ready to rock.
19mike92
12-11-2012 04:35 AM
Wettstein
02-03-2011 12:03 PM
1-5-3-6-2-4
10-12-2008 05:43 PM
Dieselcamper
11-06-2006 06:37 PM
Quick Reply: How can I get 400-500hp?
