Holset Super 40
Holset Super 40
Was thinking of upgrading from my HTT 60mm to a Super 40 due to the internal wastegate, bigger turbine wheel, and improved compressor wheel, although it's still only 60mm. Who's running one? How do they like it? They say it's good for 450 at the wheels.
It has the same compressor wheel as the he351 but the turbine is larger. A few He351 have dynoed 550rwhp on common rail trucks so I think the super 40 would be capable of making more since the exhaust should flow more. Or at least less drive pressure.
I can't remember seeing anyone running a 40 on a 1stgen (VE) make 450rwhp (#2 only). Now I don't have the best memory either, lol! Seems to me spending that much money on another turbo that is the same size is a little unproductive. Spend $1000 and get a good used 62. Are you thinking maybe the 62 would be too much with the supercharger?
Rerad this link - from another board -
http://www.1stgen.org/viewtopic.php?p=37820#37820
It discusses pro's and con's...
Interesting reading - and remember - the Hoslet flow chart is in metric
I ran a plain jane 16cm gated HX40 for a couple weeks. It is laggier then my 62/71/14cm S300 by acouple hundred rpm. But if a person could pick one up at a cheap price it would be worth it IMO. But if your thinking of buying a new one, id just spend a couple extra $$'s on a nice S300.
I ran one for a while, it was a PDR Super 40. I wasn't impressed with the spooling, so I put on an S300G. While it is a smaller turbo, it has instant boost and the truck feels every bit as powerful, and runs a little cooler. I would like to step up to a 62/65 as soon as funds permit. This is in my 1993 W350/518 with 90 horse injectors, a worked over pump, 3.73 gears and 235/85/16 mud tires. It is wastegated to 40 lbs.
I have a 6 blade HX40, 16cm T3 WG'd. It has a garret tag on the compressor cover. I got it used from the guy who bought it new. He said it was a super 40 from HTT.
I called HTT and they told me there are 6 and 7 blade super 40's.
Does anyone know what the difference is between the turbine wheel in a regular 40 and a super?
Just an FYI, "the necessary modifications so these turbos fit" is grinding some of one of the WG actuator nuts down. Otherwise the comp cover would hit the nut before the IC plumbing will line up. No big deal.
