high oil pressure reading, high coolant reading
the truck in my sig has a high oil pressure reading right at the highest bar and coolant is bouncing between half and highest bar, but i can touch rad its hot on the intake side and cool on return, i take rad cap off and does no burst out nor is it bubbling like a head gasket compression leak, and upper coolant tube is warm so it is circulating. what do you guys think could be doing this? bad ground somewhere?
Thanks, Gregg
Thanks, Gregg
it was a ground problem for sure! fixed it now next problem, where can i find body mount bushings? mine are cracked and in really bad shape! also who makes a good power steering gear box for these first gens, mine has a lot of play before it even moves the pitman arm.
thanks, Gregg
thanks, Gregg
Here's one that looks real good
http://www.pscmotorsports.com/vehicl...harger?cat=282
lap_traffic
03-19-2010 03:14 PM
GlennRMK
05-24-2007 10:46 PM
