High idle adjustment
I have read most of the posts on high idle adjs. how much is it safe to adjust out? 93 350 with fuel pin on full fuel, straight thru exhaust, air filter mods.
Thank You.
Thank You.
With the stock gov. spring, I can't see a problem with backing it all the way out. Mine is set so that the screw stops the throttle arm just before the pump internals do. I can do 70 in 4th now.
jmccart
06-12-2007 02:12 PM
