HELP (Need answer quickly) Auto Tranny Hard Line Question.
Hello Gents,
The hard line in question runs from the passenger side of the engine then turns 90 degrees and runs in front of the tranny pan makes another 90 and runs to the front of the vehicle on the driver side to a small tranny cooler.
Is this line a high pressure line?
It's been rubbing against another line that is right next to it (along the driver side) and has now sprung a leak. I'm thinking of cutting a few inches off the line, flaring the ends and attaching a hose in place with some hose clamps.
I really don't want to cut the line if the rubber hose will not hold.
IF you look up toward the transmission cooler, I believer you will se that there is a length of rubber line already installed. between the metal line and the cooler line. Just my $0.02 but I don't wee why it wouldn't hold.
This is just my opinion and I am NOT an expert on transmissions.
Carl
Carl
Rubber should hold, but if you're nervous about it, you said you have a flare tool, just flare both ends and get a connector for the middle.
Guys are right, its not a high pressure line. So hose clamps and hose will work just fine.....
92red
12-31-2010 07:57 AM
RyeThomas
18
02-26-2010 10:00 PM
