HELP Need 1st Gen Engine plate and bracket for motor mount
Hey guys,
Need some help finding some 1st Gen on engine block plate and bracket for the motor mount. Had some coming from Montana and the guy shipped them to VT not UT. They went to Vermont. Gave us a line about not being able to get them back any faster.
Does anyone know where to get the on engine plate that the brackets bolt to? Are the brackets the same as they would have used on other engines, ie. 360?
I can get the isolator mounts, but I need the plate that bolts to the side of the cummins block and the brackets that come down or at least a good picture / dimensions of what it is supposed to look like. Dead in the water...
Thanks for any help,
I appreciate it,
After looking at some chevy mounts we may go and fab our own. Dodge doesn't offer them anymore. All of the trucks I have seen they pull the plate and bracket with it.
Do you have a picture of it? I think we can fab some with plate and a piece of channel cut at an angle.
Thanks,
Thanks,
alwaysonDTR
Thank you,
That helps a lot, I shouldn't have a problem fabbing some mounts, I have some 3/8" plate and bought some 3x6 rectangular tube.
Thank you for the pictures, that helps greatly,
GR40RCapri
14
11-15-2006 04:18 PM
