Help! I've got a faint squeel only when shutting down.
Old 03-02-2009, 07:52 PM
ngrov's Avatar
Question Help! I've got a faint squeel only when shutting down.
Help guys!
I've got a faint squeel coming from my engine only when I turn it off.
It just starts a slight squeel during the last two engine cycles (if that makes sense) after I've already turned to key to stop.
I don't hear the squeel when starting or running.
It's a '93 stock 12 valve with 253k. The only thing I did different right before it started squeeling is I added the IceBox Intake. Could this be it??
Is this just a belt? Pully bearing? turbo?
Their's no way it can be the main engine bearing right??
Thanks for your help guys, I sure do appreciate it!!
Old 03-02-2009, 08:00 PM
CamperAndy's Avatar
Most likely the belt at the alternator. There is a modified alternator pulley to fix the squeak but not sure if it fits the older trucks.
Old 03-02-2009, 09:31 PM
GasganoFJ60's Avatar
A drawn out squeal? Or a quick squeak/chirp when the engine stops?
Check your belt for damage. With the belt off, check all of your pulleys for squeaks, wobble/play or damage.
Old 03-02-2009, 09:41 PM
DieselSmith's Avatar
If its a quick squeal at shutdown its completely normal, just the belt slipping a little bit on the pulleys, alternator, etc. Almost all of them do it, except my Dad's 6.7... stupid technology.
Old 03-02-2009, 09:59 PM
belt tensioner maybe
they go about every 100,000 miles and wear belts bad and make stuff squek becuase of rubbing, thats what happened to us on a previous 92
Old 03-03-2009, 07:10 AM
Bob Beauchaine's Avatar
It's the engine stopping to abrubtly for the belt to stop at the same time - thus the slight squeak.
Bob
Old 03-03-2009, 07:44 AM
RollinCoalSmoke's Avatar
When I first got my 93 I changed belts, alt. pulley, and idler pulley to stop the chirp. It lasted about 2 weeks and started again. It's just the normal shut down noise they make, cummins unique sound.
Old 03-03-2009, 08:19 AM
ngrov's Avatar
Smile
Oh Man, I'll bet that was fun.
Thanks a lot guys! I've only had the truck for a month or two and have never heard this before so I was getting worried.
I sure do appreciate your quick responses
I'll check and my belt and pulleys just incase!
Old 03-03-2009, 08:20 AM
ngrov's Avatar
Smile
THANKS MAN!!
Old 03-03-2009, 08:21 AM
ngrov's Avatar
Hey Gasgano,
It's a couple of quick chirps.
I'll go check them out!
Thanks
Old 03-03-2009, 10:14 AM
apwatson50's Avatar
Before you install a new belt, you can take a wire brush and clean the excess rubber out of the grooves of all the pulleys. This will help the new belt seat all the way into all the pulleys and possibly keep it from squeaking.
I personally have no experience doing this, just something I heard or read somewhere, don't remember where though.
Aaron
Old 03-03-2009, 10:29 AM
DNRCustoms's Avatar
I always thought thats when you know they are finally broke in..lol My 06 finally is starting to do it after a good run... The 92 does it religiously with all new stuff in the belt system.. I think it's cool!!
Old 03-03-2009, 12:23 PM
Originally Posted by ngrov
Hey Gasgano,
Thanks
Id say just pull the belt and check all your pulleys still. Also pay extra attention to the bearing that your fan rides on. Mine was worn and had play in it, but it didnt squeak or squeal at all. Perhaps yours is out as well and you just cant hear it till the rest of the motor is quiet. It could be anything. Dont leave any stone unturned.
Do you have a video camera? If you could get a clip, post it on youtube so everyone can hear. Just a thought.
Old 03-03-2009, 01:02 PM
rebal's Avatar
my 1990 has 700k on it and it has done that from day one, and I bought it new it nov. 89
Old 03-03-2009, 04:31 PM
ngrov's Avatar
I wish I had a video camera. . .
I'll go pull the belt soon. If I find anything I'll let you guys know.
Thanks a lot for your help!
Quick Reply: Help! I've got a faint squeel only when shutting down.
