Help with fuel leak and finding crush washers
So, after having my rotary pump resealed with DGK-121...my truck has become harder to start. They stopped the fuel leaks in the pump, so let's assume that the pump is not the problem.
Here are my first thoughts on were the leak is.
What is the red arrow pointing to? There are two copper crush washers there that I need. Is that a fuel line or what is it?
Is the purple arrow pointing to a potential spot for an air leak, or should it be left alone? It appears to be a flare union.
The green and blue arrows are for banjo bolts that appear to use plastic washers. Any source for those? They were in bad shape and I'm betting that's the cause of my hard to start problem.
Once the truck is up and running, it runs great.
Any ideas/help?
Any ideas/help?
Thanks guys, and yes the fuel heater gasket is also one that I'm trying to locate
I head over to cummins and see if I can round out these washers and fuel heater gasket.
Try snugging up the 13 mm nut that holds the tube in the fitting.
