Help...Electrical problem
I removed all the fusable links and replaced them with a fuse block. I now have no radio, no interior lights, and no power mirrors. I checked fuse #15 a 10 amp and it was fine. However, after checking for current there I found none. Is there perhaps a breaker hidden somewhere that might have failed or am I going to have to trace this thing through the wiring harness? Please any suggestion would be greatly apprieciated. Thanks, Kevin Smailes
1992 w350 regular cab
Hmmm, should be straight forward. Make sure you removed the full link of FL's. Just double check all of the connections, and check the fuses under the dash...lost a FS and it took out a corresponding fuse...I would replace the FL's with some fuses any day, just havent had the time yet.
