Help electrical Gremlins
So it’s 92 started off with a no start replaced a relay not sure if it’s a start or ignition relay but fixed the no start issue. Drove about 10 mile turned the corner and she just died complete electric power loss in cab. Replaced 3 of the link wires with 40 amp circuit breakers. Back running again but now no Speedo or OD. Replaced the vss no change no input voltage on the plug in to it when running and only 12.3 volts at batt when running. This morning drained batt and when I shut it off lock position key removed the oil and info center are still lit up.
