Help! broken fan clutch assembly...
I was attempting to install the fluidamper yesterday.. I could not get the left hand thread nut off of the pulley while it was in the truck so i removed the whole assembly and put it in a vice... from there i tried with just the can clutch wrench i bought.. ended up pulling the fan and attached table away from the wall so i heated the nut just slightly and tried again and i broke the threaded nub off in the nut!!! Any ideas? where to buy? I suppose i should post a wanted add in the classifieds as well but i would hate to have the same thing happen.
How is Cali. treating you Seva?
I have several 12V clutch fans on my shop shelf sitting in a neat row.
PM if you are in need.
Yeah Slayer
Yeah Slayer
Slayer fans on both side of the coast like this news.
Great to hear Seva!
Great to hear Seva!
Easiest way is to take a small pipe wrench and tuck it in behind the edge of fan pully with the jaw across pulley then take a 1 7/16 wrench and smack it to loosen the fan work's every time or get a Big pipe wrench and put it around the fan pully that will also work .
nrussell
12-04-2009 09:29 PM
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
