Heater A/C airflow direction control
My airflow directional control is stuck in the defrost position. No matter which position I put the selector switch in, the air comes out of the window defrost vents. Switch turns the air on and off ok, but will not change selection. any ideas?
Make shore there isn't and air hissing under the dash!
In the engine compartment I have good vacuum at an elbow just before it goes into the firewall. Is the selector switch just selecting different vacuum ports fed by the main line coming into it, in addition to an electrical contact to turn on the fan?
Bobcat698
02-23-2006 09:10 AM
