Heads off. Got a few ?
Old 08-07-2009 | 12:07 AM
Riflemanusmc's Avatar
Registered user
Turned out good.... Congrats...you'll be happy.
Old 08-07-2009 | 10:23 AM
roxxx's Avatar
wow nice looking work , nice to see you still can get good work done
Old 08-08-2009 | 10:36 PM
Tron's Avatar
Well its running and seems to be running good. Seems to have a bit more response. Now I will have to play with the pump some more again to see what I can get out of it.
I would like to find a turbo that would spool faster because of the low stall converter that is in the trans. It lags really bad because the rpm isn't there to spool it like the stock converter. Any suggestions?
Also thinking of bigger sticks. Something with 6 holes
Old 08-08-2009 | 11:02 PM
sdubfid's Avatar
Tron: send me a message if you want to sell your 190s. I'm in the lower mainland and may be interested. Do the 190s run clean at idle?
I went from the 16cm h1c to the he351 and was very pleased. Lower temps and the spool is the same or better.
Old 08-08-2009 | 11:16 PM
BC847's Avatar
1st Generation Admin
Nice!
Was the port guy able to put it on a flow-bench to see what kind of gains you got?
Old 08-09-2009 | 10:22 AM
Tron's Avatar
Originally Posted by BC847
Nice!
HE said he could have but he would have had to make up the plates and fittings to do it. He wanted to charge extra 200 to make stuff to fit the cummins head. So i opted not to by his suggestion as well.
Old 08-09-2009 | 10:25 AM
Tron's Avatar
Ill let you know.
pwrtripls1
05-26-2011 08:32 AM
snowmanx
06-10-2010 04:29 PM
diesel_man98
06-17-2008 09:23 AM
Swamp_Donkey
02-05-2008 12:25 PM
GoodoleBob
09-28-2006 12:37 AM
