Headlight switch
Old 10-18-2009 | 04:17 PM
Onemoparnut's Avatar
Headlight switch
Does anyone have a wiring diagram for the headlight switch? I am thinking about doing away with it and just putting in toggles for its functions. Has anyone done this can it be done without too much trouble?
Old 10-18-2009 | 04:47 PM
Bogie's Avatar
I would keep the stock switch and use relays on the headlights, and marker light circuit if you have enough to warrant it.
Old 10-18-2009 | 05:03 PM
Ronny Bailey's Avatar
Thumbs up
I agree on the relays. Higher voltage and current to the lights, you get to keep the stock switch, and the switch won't get hot from all the current going through it.
Old 10-18-2009 | 05:07 PM
I was going to do relays and toggles but it might be more work than it is worth.
Old 10-18-2009 | 06:44 PM
ChrisLib's Avatar
It would be easier to relay it, just use the original headlamp sockets to trigger the relays and build a new mini harness for the lamps.
Old 10-18-2009 | 07:51 PM
ppiggppenn's Avatar
My headlight switch burned out so badly that it melted the block terminal that plugs into it, so I've had to do as you suggest. toggle switches and relays. If your switch is still OK then I'd recommend along with the other posters to install relays to carry the main current and use the original headlight wires just to trigger the relays.
Old 10-18-2009 | 11:35 PM
dieselnut416's Avatar
heres one for ya......
my switch was burned out when i got it so i did toggles toggle 1. headlights/dash lights toggle 2. running/(4 gauges aftermarket) now the other night i had headlights on and running lights turned the heater on and bam just the head light/dash lights went about 1/2 bright the fan for the heater is on a 25 amp single curit with a toggle all i did for the lighting was find out what wire was what on the stock headlight switch and plug them in to a toggle nuthing changed but i did do a fuse block 1foot from the battery the stock wire thats supplys all power for the cab/motor is hooked direct and all the things i have done are protected by fuses oh and the gauges all went wack......
alt.... was a little above 8
oil...... was tacked out
coolant......... was middle
fule....... did not change
Old 10-19-2009 | 01:45 AM
i came up with this little jingle to remember...... and it helped me
when in doubt to figure it out ground it out
mtdoragary
11-07-2013 08:31 AM
jesse123
07-08-2012 09:04 PM
Barryn
07-14-2008 09:30 AM
jlipskoc
10-24-2005 01:16 PM
2nGlenn
03-11-2003 01:51 PM
Quick Reply: Headlight switch
