Headlamp Switch on the Glitch
For awhile now my truck's headlamp switch has been on the glitch. It seems like when I turned the dial (to dim the instrument panel) it would cause the gauge lights to flicker on and off. Sometimes it would be off completely and I would wiggle the switch a bit and it would flicker on again.
Now it has gone out completely. Headlights work, interior lights work, but no instruments lights???
I bought a new headlamp switch on Rock and after installation... no gauge lights!?!?
Based upon my previous experience with this issue, I thought, no question, it must be the headlamp switch, but now I'm left wondering if the one I got is broken? ...does anyone have any other ideas? Any ideas on how to test electrical connections?
Best bet if there's anything wrong with the connector at all when you change the switch is to change the connector also.
Relays on the headlights eliminate most of the heat. A relay on the clearance lamp circuit help with 1 tons or if you're pulling a trailer, especially if it has lots of lights.
Did you also experience the same flickering that I did when you would dim your instrument panel?
I did on mine... the flickering that is.. I replaced the connector by putting a blade fitting on each wire, just used the partly melted connector housing to keep them organized a bit..
Ya, I had the flickering also...Then had no tail lights or instrument lights....I unhooked the old harness off the switch and cut the wires as close to the old pin connector as possible.
Then I used some good connectors and spliced the new 9-pin connector onto the factory wiring harness
Shilohman
08-27-2010 12:14 PM
royta
01-17-2009 03:25 PM
njmaier
04-26-2005 09:13 AM
