Head Milling
Head Milling
Ok, my machinest advised that we do not mill the head because it has conformed to the block. Thoughts?
-mark
-mark
Wow, never really heard that line of thinking before. I generally go over each surface carefully with a straightedge and feeler gauges first, before I decide whether a head needs to be sent for machining. Have seen many heads that needed straightening, but can't remember a block that needed resurfaced.
He said if you are not going to mill the block (which I obviously can't do in frame) that milling the head is a mistake. I'm a little worried about the front passenger corner of the head where it tends to leak.
Haven't pulled the head yet, waiting for the studs. He worked for Rocky mountain Cummins for a number of years back in the day. Like I have said elsewhere, he is one of the best engine builders/machinests in the country, and I really respect his opinion.... but he doesn't do performance diesels!
if the head comes off, i recommend it get machined. it will always be warped on the exhaust side, naturally, due to excessive exposure to heat. even if it only needs .001" to get it flat, it's worth it.
Yes i agree, if in doubt Mill it!! Just get a .020 over marine gasket and you can take up to .020 off the head and still be at stock comp. Not to say that your guy is wrong . For a in chassis thats the norm. Mainly big truck motors thou. If he argues then ask him what 2 do if you put a new head on?? just saying...
Dusty Ratcliff
04-10-2006 07:35 AM
OT-OF-Here
08-07-2004 07:56 PM
