Head Gasket Leak?
Front crank seal AND wear sleeve kit 3802820 $83.23.
I wouldn't dare try anything aftermarket for this repair, use Cummins parts only please.
I used the balancer and it's bolts to pull/install the wear sleeve. You don't need the high dollar install tool. A good Cummins manual is handy, but if I remember right, it said to clean the crank up good, oil it and the wear sleeve (although don't quote me on the oiled part) to aid the install.
Yep, oil the sleeve and crank, then clean everything up real good because it must be oil free when the seal goes on. QD contact cleaner is your friend.
I should have done the head gasket I think. Looks like I have a new crust forming.... I was really hoping it was the thermostat housing, but I guess I knew better.
ted_pulliam
07-16-2009 11:33 AM
wildchild97
09-25-2007 02:44 PM
Conn
12-29-2006 06:30 AM
