He351cw
He351cw
HE351CW with 60mm x 88mm Super HX40 compressor wheel.
Would this be a great upgrade to replace my H1C? Is the 60mm x 88mm Super HX40 compressor wheel better than the stock HE351CW compressor wheel?
Yep, that turbo would be an excellent upgrade for your engine! Especially if you can control the exhaust brake part... And there's another recent thread with the same HX40/HE compressor wheel question, but can't remember the answer. Let me see if I can find it....
... found the thread, but no actual numbers. I'm sure if you looked hard enough you'd find some though. The wheels are a little different, although they do look the same. I'd just stick with the stock wheel, as guys are seeing up to 40psi of boost, (maybe more) which is more than enough!
I got a nice cool, 35psi with the wastegate wired shut through my Cooler Tubz and Powerstroke IC. Thinking about making the wastegate open though. High boost doesn't always mean more power. Backpressure can have large pumping losses.
jesussaves
0
04-21-2009 12:04 PM
PaulDaisy
09-13-2008 08:42 AM
