Have "YOU" been killed by a KDP or KTCB?
I bought mine with about 200K on it. Pulled the vaccum pump to do the seals and found that the KDP had fallen out. When it did, it bent the drive gear. The PO had no idead it had fallen out.
What does the KDP sound like when it comes out? Years ago I was sitting in a parking lot idling when I started hearing this jack hammering sound. I looked around and didn't see any equipment around so I shut her off. My wife said it was the truck. I popped the hood and thought I saw a wisp of smoke. I restarted and everything seemed fine - no noise, no leaks. That was years ago.
It does make me wonder though!!
Killer Timing Cover Bolt- I am guessing-.. the bolts can sometimes work loose and cause the same damage as the dowel pin..have heard of people finding them loose, but havent heard anyone say they had damage because of one
Thats it exactly, Form what I hear you can survive the KDP, but at least one of the cover bolts will break the cam, due to its placement above the gears.
When I was doing my Pump rebuild.. I fixed mine so I do not have to worry about it..
but when I did fix it , it was still in stock position.. but I figured I better do it now anyways
justin mcfall
08-24-2008 12:35 PM
DieselBoy20
08-09-2008 08:39 PM
RyeThomas
07-11-2007 04:31 PM
CUMMINSBILL
06-06-2003 10:02 AM
