hard in get in and out of 4wheel drive
It might be the shifter seizing on the shaft. Get under the truck and spray all the linkage and pivot joints. Its best to do it while someone else is moving the shifter back and forth.
My autotransmission keeps it tight. Though I can shift from 2high to 4high on the fly...going in and out of 4low is tough. Like said above, the truck has to be on level ground in neutral, w/o brakes, so everything in the driveline is relaxed. Sometimes it takes me a few tries to get it out of 4low.
i hav the same problem ill be in 4x4 low and being really hard on it and then when takeing it out i could pull as hard as posible on the shifter and it wont come out but if i put it in reverse then forward then reverse and back to N it will slip right out
why is that
why is that
TxDollBabe
10-17-2013 11:15 PM
c2equine
12-19-2009 12:39 PM
Lurch12pumper
02-03-2009 06:57 PM
Jim Weed
03-18-2005 04:07 PM
