gray valve cover gaskets?
The link in the sticky says don`t use the gray ones,use the black ones. Well I went to Cummins dealer yesterday before reading the sticky and they gave me the gray ones. Whats the deal?What`s wrong with the gray ones?
Oh, also the cam button for TDC is froze up. Is there another way to adjust the valves? I want to do that while I`m in there
As far as re-using them, I've found the gray ones like to pop off the valve cover as soon as you remove it, then they won't stay on long enough to put the cover back on the engine. The solution I've had luck with was to stick the gasket in the freezer for a little while. They tend to co-operate better when they are cold.
