Got oil in my fuel pin
I picked up A 90 cummins for A motor swap, thing runs great but I went to change out the fuel pin and the hole was full of clean oil. I've had an issue with fuel getting in there on my truck but don't see how oil can get in. Especially clean oil. Any ideas?
I don't think it would, the pin is under tension. As the pin rides the ramp the spring tension opens it up. I see the idea of lubricating the ramp so the needle doesn't get worn out. I usually put a small amount of grease on the ramp for lubrication. Motor oil isn't a bad idea.
Couldn't get it completly full though, the cavity under the diaphragm is vented to the atmosphere, remember the rubber boot above fuel screw, thats why it leaks fuel.
gaberichison
12-21-2014 12:21 PM
Cowboy_Customs
10-18-2011 01:46 AM
