got a new trick for drilling EGT hole in maniflod.
I came up with a pretty cool trick for drilling the EGT hole without worry of the shavings getting in the manifold. Stuffed a towel in the exhaust pipe and started it up. the towel creates back pressure but lets it still run. Drill the hole and the back pressure blows out the hole before the shavings ever get a chance to fall in. Being diesel exhaust at idle its not hot enough to burn you instantly. Using a little drease on the bit also helps catch most shavings.
Hey, i know it sounds crazy, but it works great.
Here's what I did. I was fortunate to find that the bolts that hold the turbine housing to the manifold were easily loosened. I loosened them so that there was maybe a 1/2" gap between the two housings. Then I drilled the hole, not worrying about shavings. Then I fashioned a plate out of very thin aluminum, a pop can may even work, that slid down between the studs that hold the manifold to the housing. I made sure the plate was resting tight against the turbine housing. Then I started her up. The exhaust blew all the shavings out of the manifold but the aluminum plate didn't let them enter the turbine!
Shorts
45
06-25-2017 12:19 PM
baddodges
02-09-2012 01:57 PM
webguns22
05-11-2008 08:00 PM
2006zo6pilot
11-22-2007 11:11 AM
Dave65
14
10-08-2004 10:37 PM
