Got my junk dyno'd today
Old 04-30-2010, 12:57 AM
big stinky's Avatar
First run, tow tune, (pump maxxed, timing 1/16 advanced, ksb connected)
331hp and 725 lb/ft.
2nd run, full advance, no ksb.
388 hp and 798 lb/ft.
This is done with stock non i/c sticks, super 40, minor head work (20 over head gasket), and a carter 4601hp that pushes 8psi at wot.
Dyno was a dynocom dyno. Runs were in 5th gear.
My sheets are in my truck, i cant remember the rpms those power numbers were at...
Power ran out by 3200... Gotta do some more fiddling with that to get some more rpms out of her...
Thought 50 hp for a timing bump was quite nice! BUT, im pretty sure I can get that last 12 hp with a little bit of tuning... Bwhahaha!
Old 04-30-2010, 01:14 AM
Best Paint (Getrag category)
pulltilbroke's Avatar
Nice numbers Stinky
I gotta do a little tuning and I should hopefully be right there with ya
Old 04-30-2010, 01:28 AM
big stinky's Avatar
Thanks man, I'm sure if you give it a couple wirlygig raps and maybe a thing bob shave, you'll be there...
Old 04-30-2010, 01:49 AM
I did grind a special pin and take some low end fuel out of it today and I did wash the crap out of the motor today and it seem to run a lot better.
Old 04-30-2010, 07:34 AM
dzl_damon's Avatar
Impressive. So you went from a 1/16" bump to the head and got 57hp and 73ft-lb?? Wow. Almost 400hp on stock non IC sticks is nice! I gotta hook up my Carter pump now! Congrats
Old 04-30-2010, 08:37 AM
soggy's Avatar
Nice numbers.
Old 04-30-2010, 09:39 AM
apwatson50's Avatar
Nice, do you have an IC and how much manifold pressure were you at? What clutch do you have?
Old 04-30-2010, 09:50 AM
pwrtripls1's Avatar
Thats a ton of power for stock non IC sticks!!! Like 80whp more than anyone I've ever heard of. I'm def curious what all you did to the head and pump to get that much fuel out of stock injectors.
This does give me some hope that I could make alot of power with the DDP4's.....LOL
Old 04-30-2010, 09:51 AM
Dieselbuilder's Avatar
so you like my dyno
Old 04-30-2010, 10:00 AM
big stinky's Avatar
2nd gen cooler, and piping. Somewhere around 40 psi. Couldn't really see. South bend 350 hp clutch.
Yes you can.
I have heard of 400 rwhp with non i/c sticks, but that was on a dynojet. The head i gave a minor bowl blend, and cleaned up the sharp edges. I didnt take out a lot of material. The manifold I ported just to match up the holes. The pump is maxxed with a m5 fuel pin, clipped 3200 gov spring, full throttle travel mods, and ground a bit out of the afc lever.
Originally Posted by Dieselbuilder
so you like my dyno
Malcom?
And thanks for the compliments guys...
Old 04-30-2010, 10:34 AM
JQmile's Avatar
uncorrected numbers? Nice job!
Old 04-30-2010, 08:11 PM
big stinky's Avatar
Not sure, didn't hear any speak of corrections... I will assume that, but we all know what assume means...
Old 04-30-2010, 08:17 PM
Did you get a Dyno graph?
Old 04-30-2010, 10:02 PM
1st Generation Admin
BC847's Avatar
Nice work.
Old 04-30-2010, 11:34 PM
u.s mma's Avatar
this gives me hope. how does the rag sound while you are towing with 300plus? what kind of weight do you tow and how are the egt's?
Quick Reply: Got my junk dyno'd today
