Got the 1st gen dynoed
The bigger turbo you get and/or the more timing you run, the less likely you will maintain 2:1 ratio.
Hx35 with 1.55 mm timing you will do it.
Using a 62/71/14 and 2.25 mm; probably not.
the optical pick-up was messed up. It was reflecting off my pick-ups for my tach and all sorts of crap. Mike said not to pay attention to the numbers too much.
I think it would make more power on a load dyno where you could get the turbo spooled earlier...I only have the 3200 spring, but I know my pump is pretty much done by 2800. Even with the 4K spring it still looked like your peak power was down lower. Add some timing and see where it goes from there. Also I think you could use more fuel if you only picked up 90 hp at the wheels with an .080 jet. Maybe it's time for a 14mm
Silver 62
Pump Mods
3200 Spring
Goerend Convertor and Built 727 Tranny
Walbro 392 lift pump
82 Jet For The Nitrous
Sprayed on teh second and third.
