good combination?
good combination?
I need some advice, id like to make my 91 a nice looking, fast running 1st gen.
truck:
1991 W250 reg cab
1990 non I/C engine
getrag 5spd
3.54 gears
mods:
fuel screw 1 turn from run away
diaphram turned
3" straight pipe into 5" stacks
BHAF
now would this be a good combination of parts for an everyday driver/part time tow vehicle?
intercooler from a 99 (in my basement) with 3" piping
either 6X16's or PODS?
a fuel pin, possible DennyT pin
ATS 3 piece manifold
an S300/S400 compound turbos (or HX35/HX50??)
head studs
advanced timing
4" turbo back exhaust into 7" bullhaulers
Southbend clutch
NV5600 6spd
6" lift with BFG A/T's (the KO's) 35X12.50 R16's
stock 3.54 gears
Factory 2 tone but a dark dodge blue with metallic flake and marbleized silver?
air brush the embelems on then put 5 coats of clear over the top of the whole truck.
also a moon visor from Lund
reg. cab chrome nerf bars
Also any ideas on fuel system upgrades like a FASS system that will work or?
any ideas comments, concerns on parts combination or paint please let me know. i want to do it right the 1st time
truck:
1991 W250 reg cab
1990 non I/C engine
getrag 5spd
3.54 gears
mods:
diaphram turned
BHAF
head studs
advanced timing
Southbend clutch
NV5600 6spd
stock 3.54 gears
sounds good.
I'd screw the NV5600 idea, its heavy and very large,, its alot of work to make it work in a 1st gen and doesn't seem worth it unless you tow like a million pounds.
H1C??? for a small turbo? isnt that a little too small lol or get the 60 mm upgrade and a HT3B? and benjamin, i may only be 18 but i built the truck the way she is in the 1st place lol. took 2 heaps of junk and made one good truck. now i want to make it better haha. where can i get the 6X16's? i kno they are schied i believe (spelled wrong i think) but do they have a website?. also wanna, y is airdog better than fass? im just curious
A 91.5-93 H1c has the same specs as an HX35, except the exhaust housing.
I'd do a H1C with 60mm GDS kit, with a 12cm housing.
With a HT3B big turbo.
Scheid has a website, just search GOOGLE
Airdog seems to know 1st gens alot better than FASS, and airdogs are quieter from my experience. It has to be set at 15psi or lower for it to not hurt the pump.
well i think i already have the 12cm housing. its a 1990 engine with the stock H1C. so the 60mm upgrade and a HT3B. k i got that part. i knew about the 15 psi limit. would an electric pump from summit and a filter relocation kit work the same?
no a 90 Stock H1c would have a 18cm housing.
Put a 12cm wastegated on your secondary,
and why not put a 60mm wheel on your secondary? More air = more power.
And if you don't get the 60mm wheel/housing then you don't get a MWE slot. because H1c's dont have it.
