Getrag Trouble--Clutch or Trans?
Old 01-10-2007 | 05:22 PM
aicomp's Avatar
Hi All,
Coming home tonight my trans was in 5th gear and all of a sudden it was not working. 5th gear got me home, but I had no other gears. There was no unusual noise or anything, just no gears except 4th. Now, it will not move even in 4th. I have no idea, and any sugestions will be appreciated.
Thanks,
Mike
Old 01-10-2007 | 05:34 PM
apwatson50's Avatar
Sounds like the shifter part of the tranny is worn out and when you pulled the shifter out of 5th, the shift fork stayed in 5th, therefore you only had 5th gear.
Put the shifter back into 5th, then push the shift lever to the passenger side of the truck and the pull down and hopefully it will come out of 5th.
Old 01-10-2007 | 05:42 PM
aicomp's Avatar
Hi,
I now have no gears. I can shift into any gear and let out the clutch with nothing happening.
Mike
Old 01-10-2007 | 06:58 PM
Well, at least you got it in neutral now.
The trans is going to have to come out and the toploader will have to be fixed. The rails or the shifter (or both) are worn out.
Old 01-10-2007 | 07:40 PM
aicomp's Avatar
Cool
Hi <
Thanks for that. I guess I knew I would have to pull it out, But I only have 383000+ miles on it and the clutch. I would think that it should still be under warranty,HA HA. I appreciate all of you great folks on this forum. You are all great folks, and I have learned a lot.
Thanks ,
Mike
ridlangus123
12-30-2013 08:36 PM
vr1967
08-27-2012 02:29 PM
pridero
03-21-2011 08:46 PM
njoh820
03-03-2010 02:10 PM
Magnum Salvage
09-24-2007 03:34 PM
Quick Reply: Getrag Trouble--Clutch or Trans?
