getrag swap...
Your driveshafts from the 727 should be the same as a 5-speed. the one's that are different are the 518 shafts. I had a front shaft from a 5-speed truck in mine when I had the 727 and they were the exact same length.
Huh that is weird on my 2wd 727 to Getrag swap in my '89 I had to shorten the front half of the driveshaft 3" for it to fit......
So putting a nv-4500 where a 727 was in a 4 wheel drive truck - the 'shafts will be wrong as the nv-4500 is longer. Could I use a 518 front shaft as those are longer than the 727 ones?
