Getrag ?'s Top cover needs help
My shifter is geting prety loose a while back I got the truck stuck in gear, and had to pull the shifter to get back in neutral. I put a bead of weld on the shifter stick so it wont fall between the rails for a little longer but the cure for the problem is a rebuilt top cover because the forks are geting prety wore I am sure.
Where do you sourse parts for these raskals, and I hate to say it but maybe I should take the plunge for an nv4500 while my current getrag has some value. I'm all ears, thanks Jon
www.zbag.com is good for new and used getrag parts.
