Getrag oil change= wont shift
Old 04-26-2010, 04:54 AM
trainermg's Avatar
Just reading this and see that u say you pulled the pto cover did you put the bolt s back in that you took out or had to use a longer one or any thing like that.I have used to long of bolt and it got up against something in there .Just trying to help!
Old 04-27-2010, 11:05 PM
boxcar's Avatar
Thanks for all the help guys, I pulled the transmission today and found the clutch to be like brand new. The input shaft was worn at the nose where the pilot bushing rides and it is indeed binding in nuetral. The input and main shafts are for all practical purposes locked. I removed the front bearing retainer and loosened the bearing cone very slightly and freed up the shafts. It is clearly the pocket bearing. My next question is, what problems will I run into when I rebulid the Getrag.
Old 04-28-2010, 08:32 AM
sooty's Avatar
gtrg
price on parts for one, good time to upgrade to 4500, ive got a parts connection up there called txchange.com, portland, they do reman, and parts, used, or new.
firstgen250
09-30-2010 11:45 PM
rustydeeretech
06-16-2010 09:41 AM
boxcar
05-15-2010 12:14 PM
thumbs
11-04-2007 06:41 PM
Nathan
12-19-2006 03:59 PM
Quick Reply: Getrag oil change= wont shift
