Getrag/HX35 boost numbers?
Im used to my h1c and 727 boost, when I would run up to 10-12lbs of boost at low speeds. On a test run with the getrag and hx35 installed with new crossover, I cruised about 25-35 and just under very light throttle saw around or a little below ten, and under 3/4 throttle in 4th hit 32. Just wanna know if this is about right? It seems like it, cause the truck is VERY POWERFUL now, makes it look so weak before. Thanks.
With my pump cranked 1/2 turn from run away, I get 35psi under a hard pull and about the same as you during easy driving. That hx35 sure makes it a different tuck doesn't it?
Sounds about right to me. I see a max of 38 PSI with my boost elbow closed and on the dyno. I rarely hit 30 PSI in day to day driving. I just don't have to get on it that hard.
Bob
Bob
What #'s areseen with a hx35 with 18.5 cm and the fuel screw turned to the lock collar, and the timing bumped on an auto? i only see 20-24ish at wot, and a slightly signifigant haze.
A smaller housing will spool faster. I replaced my 18.5 with a 16 before I got on DTR, otherwise probably wouldnt have. The Hx I got came with a 14, so I just used that one. I couldnt tell you the difference from 16 to 14 as theyre behind diff turbos, but I did notice a minimal difference in the 18.5 to 16.
bgilbert
12-27-2009 06:31 PM
sCreamin400
11-02-2008 01:46 PM
xloudnproud
22
04-27-2006 11:41 AM
ClawHammer
08-07-2004 08:49 AM
Captain Insane-O
01-11-2004 03:08 PM
