Getrag backup light switch
Ok, I have to admit that I gave up after 5 hours trying to get the old switch out. I tried everything, including a chisel and hammer through the shifter hole. I could have pulled the transmission in the time I worked on it . I need to leave for Mexico so I just wired a switch to the lights, but as the guy in Dirty Harry said, I gotsta know, how do you get the backup light switch out without removing the trans? I am stumped, what is the trick?...Mark
Cummins Guru
I had to grind a socket to fit, sorry it's in my tool box at work otherwise I would have taken a picture of it to show you how I made it work. Monday would be the soonest I could post picture of it.
I made a tool that would have worked out of one of those thin sided sockets that are used for small motor spark plugs. but it was too long and I couldn't turn it. What is it with German engineers not giving enough space to fit a tool? Between the FSS and the backup light switch, I don't think it's an accident...Mark
And you can park in the best spot in the lot, turn them on, and go sit and watch the ensuing hilarity!
I did that in my Jwwp once and the guy put his car in reverse and gased it into the car behind him.
When I was much younger at Christmas time my brother and I would sometimes stay in the car (1953 Buick Roadmaster) while my parents went Christmas shopping at the big Sears Robuck in Los Angeles on Soto Sreet, when there would be long lines of cars waiting for a parking, we would step on the brakes and watch the cars stop behind us and wait for us to leave. A few times people would get out and beat on our window and swear at us and threaten to call the cops.
That was fun.
Jim
It is 24mm and my tranny is still in the truck. I have a tool that I made out of a small engine spark plug wrench and I am sure it will work, when I pull the tranny next time (if there is a next time). I can live with a switch till then...Mark
Yeah, I forgot how much of a tight fit that was. Even if you cut a hole the socket needs to be perfect or else it won't gab the nut.
I'll check the manual tomorrow, but it is probably a good idea to check all the fuses, especially for amp rating. Over the years, and I am guilty of it, a fuse would blow, a 20A for example, and all I had was a 15, so in went a 15. I found a 25 in the 10A radio spot, and 15s in 2 spots for 20s. I found a blown fuse for the brake lights, but the switch was bad and probably caused the fuse to blow. I do remember that there is a backup light fuse, but I don't recall which right now and will check tomorrow...Mark
