getrag
getrag
What kind of oil do you put in a getrag?The manual says 5w30 sg or sg/cd rating. Couldn't find any with these API ratings in town, are there newer API ratings that work the same. Would synthetic be better.
Pod Boy (on hiatus)
Any 5w30 should work. Synthetic is recommended. I run Redline MTL. Kinda pricey but I noticed a difference in shifting over the standard 5w30 synthetic I was running. Lots of guys use the Royal Purple fluid and like it as well.
Same here; five quarts.
Factory fill is 3-1/2-quarts; most people over-fill to five-quarts; there are more ways to accomplish the over-fill than there are to skin a cat.
Whichever method you choose to over-fill, I strongly suggest you choose one that incorporates a dip-stick; as, when you just dump the extra down through the shifter or a high PTO bolt-hole, you leave yourself with no means of monitoring it's level.
If it's stiff shifting, try a trans oil like Royal Purple Synchromax or Redline MTL.
If it's a hard working truck, keep in mind that these will run a little hotter than Mobil1. A tow rig should use that and learn to be patient.
1stGenBikeHauler
10-29-2002 11:48 PM
