Generic D70 rear end swap
Old 05-04-2006 | 07:16 PM
csramsey640's Avatar
OK I recently came across 2 d70 rear diffs from early model pickups(dodge) one 3.73 and the other is a 4.10(i think thats it). Can I swap in one without hooking up the ABS sensor? I know neither have a tone ring, but I cant say I have ever felt my abs work anyways.
Any thoughts?
Old 05-04-2006 | 07:31 PM
BearKiller's Avatar
Go for it.
You may have to relocate perches, shock mounts, etc., but no big deal.
Also may need to swap pinion yokes, or swap drive-shaft yokes to match.
My old Chevy has had no less than three different D-60's out of Dodge trucks; I swapped the drive-shaft yoke to Dodge, relocated spring perches, and welded on shock hangers.
It is easier than it sounds.
Old 05-04-2006 | 07:37 PM
I guess I shouldnt say "early" They are all 80's rears, same body style but neither are ABS rears.
Old 05-04-2006 | 08:36 PM
Redleg's Avatar
Don't forget to compare bolt patterns unless yuo don't mind odd wheels. Watch wheel spacing too. When I was looking I ran across some out of vans and RV's that were pretty narrow despite being duals, includeing 5 bolt, patterns.
Old 05-05-2006 | 03:22 AM
frostie's Avatar
I would go with a direct swap. if it isnt a direct swap Dana 70 then I would spent a bit extra and do a Dana 80 convertion. Its a bit harder do break a Dana 80. The rear disc is another bonus.
getstucksome
07-30-2010 11:10 PM
sleepr tsi
07-19-2008 02:22 AM
Bounce
06-22-2007 02:42 PM
1320
08-19-2003 05:28 PM
