GDS 60mm compressor on!!
Old 12-28-2007, 01:25 AM
COUNTRYBOY's Avatar
On The List
Well I called today and got my name on the waiting list, I can't believe the price! It's worth at least a try... Of course to me turbo noise is priceless.
Old 12-28-2007, 02:17 AM
MoparMarv's Avatar
whats the cost on the 60mm compressor set up?
Old 12-28-2007, 05:03 AM
COUNTRYBOY's Avatar
PM sent...
Old 12-28-2007, 07:29 AM
CaptainChrysler's Avatar
The whistle has a different sound to it too. It's kind of deeper, like a big turbo.
Old 12-28-2007, 11:07 AM
bigragu's Avatar
I don't mean to hack in, but I am curious as to what mm pinwheel the PDR hybrid HX35 compressor housing has. This is what I have on my W250 1993;is the kit you got basically doing the same as mine(the hybrid from PDR uses a 16cm NWG exhaust housing) or more of an improvement? I was always curious about this in other related treads on the subject of pinwheel sizes. Again, sorry to hack in.
Old 12-28-2007, 09:59 PM
toyz's Avatar
Is this a better upgrade than an HTB, a Garret stage 2, or an S300 that would have a 60mm compressor wheel?
Old 12-29-2007, 06:57 AM
No. The turbos you mentioned have a larger turbine and can flow more exhaust out of the engine, lowering drive pressure and allowing more air to flow into the engine.
Old 12-29-2007, 08:07 AM
C/PRD/'s Avatar
Not to mention better shafts and bearings. They'll handle the drive pressure alot better than the small holsets.
Old 12-29-2007, 09:54 AM
bigragu's Avatar
I am assuming now then that my hybrid from PDR doesn't come with the 60 mm pinwheeel, so my question is will a 60 mm wheel work on my hybrid HX 35??
Old 12-29-2007, 09:58 AM
Free89W350's Avatar
I assume that you can get a compressor wheel upgrade kit for the HX35. When I started looking around for my compressor upgrade everyone also carried one for the 2nd gen Hx35's. Do some checking I'm sure you can find something.
Old 12-29-2007, 10:04 AM
gman07's Avatar
The PDR HX35 has a 58mm wheel; the difference between the 60 and the 58 is probably not worth what it would cost you.
12V_shooter25
01-11-2013 04:07 PM
Richie O
03-20-2009 10:07 PM
pwrtripls1
01-05-2009 06:49 PM
'91 VE
12-12-2008 12:17 AM
vr1967
04-14-2008 02:18 AM
Quick Reply: GDS 60mm compressor on!!
